Release: 0.7
v0.7 - 2020.1
  • Added support for .psd, .bmp, .gif formats
  • Added single material export
  • Added blend modes for layers
  • Added blend modes for brush
  • Added plugin manager
  • Added ‘auto-save’ plugin
  • Added ‘hello-node’ plugin - custom material node
  • Added ‘console’ plugin - run commands
  • Added ‘profiler’ plugin - performance graph
  • Added ‘converter’ plugin - convert .arm files into .json
  • Added ‘import_tiff’ plugin - support for .tiff format
  • Added ‘import_stl’ plugin - support for .stl format
  • Added ‘import_gltf’ plugin - support for .gltf/.glb format (alpha)
  • Added ‘uv_unwrap’ plugin - auto-generate uvs / unwrap active mesh
  • Added ‘theme-editor’ plugin
  • Added box selection to node editor
  • Added per-fill-layer uv control
  • Added option to split .obj mesh by groups or materials
  • Added ‘decal tool - scale x’ option for non-square decals
  • Added ‘menu - file - reimport mesh’
  • Added ‘menu - viewport - split view’
  • Added ‘preferences - restore’ button
  • Added ‘preferences - native file browser’ option
  • Added ‘preferences - viewport - vignette’ option
  • Added ‘preferences - usage - dilate radius’ option
  • Added texture export presets
  • Added ‘layer’ material node - drop layer onto node canvas
  • Added ‘layer mask’ material node - drop layer mask onto node canvas
  • Added ‘blur (image)’ material node
  • Added experimental dxr build
  • Added path-trace (dxr) viewport mode
  • Added ao (dxr) bake
  • Added bent normal (dxr) bake
  • Added lightmap (dxr) bake
  • Added thickness (dxr) bake
  • Added normal-map bake from high-poly
  • Added height bake from high-poly
  • Added dilation pass to baking
  • Added ‘up axis’ option for relevant bake types
  • Added support for drag and dropping multiple files at once
  • Added popup for editing RGBA node sockets
  • Improved gizmo
  • Improved height paint
  • Improved .obj importer
  • Improved .blend importer
  • Improved outliner
  • Improved node drawing performance
  • Improved layer handling performance
  • Improved key detection on linux
  • Fixed handling of accented filepaths
  • Fixed brush mask on linux
  • Fixed copy-paste on linux
  • Fixed window title updating on linux
  • Fixed file association
  • Fixed envmap import
  • Fixed object mask for fill layers
  • Fixed height displacement scale
  • Fixed blurry text on windows
  • Fixed texture filtering option for image node
  • Fixed key repeat for text edit
  • Updated dark and light themes
  • Updated menu bar structure
  • Reduced gpu memory usage
  • Faster texture loading
  • Undo for layer opacity and blending
  • Undo for node canvas
  • Adjustable viewport clip distance
  • Remember window size and position
  • Open node search on link drag
  • Resizable ui panels
  • Duplicate material
  • Use brush ruler (shift) to draw lines
  • Auto-set 2x scale on high-res displays
  • Flat shading for viewport modes inspecting pbr channels
  • Picker tool works on non-base layer
  • Picker tool shows texture coordinate in 2d view
  • Export single texture from textures tab
  • Eraser takes hardness and opacity into account
  • Export textures as udim tiles for udim projects
  • Download ‘texture-synthesis’ plugin preview
  • Download Unreal Engine live-link preview
  • Download Unity Engine live-link preview
