[need help] temporarily hide a fragment of the model
hello,
i have a model of a hoodie, and i’d like to place some decals on it (i’ll try that out with the already made How-Tos), however, there are drawstrings blocking the front of the hoodie. Is there any clean way i could temporarily hide them without editing the model directly? I know where they are on the texture file, so I could attempt this by masking them out, for example
model in question: https://booth.pm/en/items/8089665
Hello and apologizes for the delay,
If drawstrings are not a separate object which can be hidden in Meshes tab, then one other way to do it is this:
Paint the drawstrings to mask them. It can be done via a paint brush like usual, or if they are on a separated UV island then one quick way is to select the Fill tool and use UV Island mode.
Open the 2D view and press Edit - Capture Output button. This will save the mask into the Textures tab.
Select Color ID tool, assign the mask as a Color ID Map, click on the hoodie (in my case I clicked on the cube instead of cylinder) and enable the Viewport Mask option.
Now when paint brush is selected, the cylinder is gone.
