[1.0-alpha] Crash when trying to bake Normal from high poly
Whenever I click bake on a Bake Texture node set to “Normal”, ArmorPaint crashes (justs closes with no error message). Tried multiple meshes and even the default cube.
If I set the Bake Texture node to anything else other than “Normal”, it works. It’s only baking the normal map from a high poly that always crashes Armorpaint.
Here are my system specs:
OS: Windows 10
CPU: Intel i7-7700
GPU: NVIDIA RTX 3060 ti
GPU Driver Version: 610.62
Also having this issue. Literally any model, trying to bake the high to low poly makes the whole thing crash with no message. Specs:
Linux Mint 22.3
GeForce RTX 2060 SUPER
Driver 595.71.05
Intel i7-9700KF
Same Same.
Kubuntu 24.04
5900X
3080
Driver Version: 595.71.05
Found the issue, many thanks for report! Will be fixed in the upcoming build.
Great to hear, thank you. I’ve been waiting this fix to try the software on a real project, so I’m looking forward to it.
On a related note: I see in the manual that apparently height and normal are the only maps that can be baked from high poly to low poly.
Do you intend to add baking AO and Curvature from high to low poly? For low poly workflows these are pretty important, since these maps can have very different results if baking from a high poly compared to baking from the low poly itself.
